(9700-0112) Networking Alpha Signs Manual
Page 29: In the table under Typical use,
Item B is actually part number 1088-8621, a 3-foot 6-conductor
cable.
(9708-8061) Alpha Sign Communications Protocol
Page 81: Under the Control codes heading
in the Dec 28 and Hex 1C row, the signs referred
to under Meaning should be AlphaEclipse 3600s, not 3500s.
(9711-6009) AlphaEclipse 3500 Series A Sign Service Manual
Page 31: Guidelines for installing the temperature
probe have been revised. See Temperature Probe
Installation Guidelines (TechMemo 03-0006).
(9711-6015) AlphaEclipse 3500 Series B Installation Manual
Page 39: Guidelines for installing the temperature
(9711-6019) AlphaEclipse 3500 Series B Sign Service Manual
Page 29: Guidelines for installing the temperature
(9711-6501) AlphaEclipse Time and Temperature Sign Installation
Manual
Page 8: Guidelines for installing the temperature
(9711-7001) AlphaEclipse 2500/2600 Series Installation
Manual
Page 37: Guidelines for installing the temperature
| (9711-8001) AlphaEclipse PureColor 3600 Series Sign Installation
Manual |
Page 166: Guidelines for installing the temperature
Where referenced: The part number for the
temperature probe cable is 71220401. 71220400 is incorrect.
Where referenced: Adaptive standard RS485
outdoor plenum 2 conductor shielded cable (pn 7122-0284) is the
only RS485 cable that works successfully with outdoor displays.
Category 3 cable, Category 5 cable, and other cables do not work
reliably and are not approved by Adaptive for use.
